turn signal bulb change
Old Dec 12, 2017 | 1:32 PM
pdelano's Avatar
Default turn signal bulb change
Hi, have a 2015 suburban ltz, trying to change the drivers side turn signal bulb. Cant figure out how to get to it...the bracket (that looks like a 2nd battery tray) is seemingly impossible to remove without removing the entire fuse/electrical box and the water reservoir is in the way from the bottom and from the wheel well. OMG. can get to both headlights but not to the signal bulb just under it.. any tricks?
Old Dec 13, 2017 | 6:36 AM
This might help.
https://www.carcarekiosk.com/video/2...n_signal_front
Old Dec 13, 2017 | 6:03 PM
pdelano's Avatar
Thanks, I have watched this.. great for the passenger side but it implies that the driver's side is simple! It is not! I was able to finally squeeze my hand down in there and i could feel what i thought was the housing for this bulb but i was unable to get it loose.. so, i put it all back to together and now it is working! lol... so, if it happens again it will go back to dealer and hopefully be covered under warranty as apparently its not the bulb!
