unable to start engine with 6 gallons in tank
Old Aug 17, 2014 | 9:26 AM
Dan1953's Avatar
Default unable to start engine with 6 gallons in tank
Newbie here-
I am unable to get my 2003 5.3 liter Tahoe engine to start when the engine has been off for a few hours and the fuel gauge is ¼ of a tank or less. I can get the engine to start by adding a couple of gallons of gas. I filled the gas tank full immediately after adding about 2 gallons and the fill-up required 18 gallons, so I should have had about 6 gallons in the tank. Can the fuel system lose pump prime?
I am not the handy sort and I am not going to fool around with the fuel system, so this will have to be a professional fix.
Old Aug 17, 2014 | 1:24 PM
Welcome to the forum.
Check fuel pressure. It sounds like your fuel pump is going south.
Old Aug 17, 2014 | 7:24 PM
NothinbutChevy's Avatar
I agree! Unfortunately it sounds like you are going to have to get your hands dirty. Check the fuel pressure and you can always bang it with a rubber mallet to see if it will come back to life. - had to do it a couple of times at the shop to bring cars in and out of the stalls.
Old Oct 1, 2014 | 6:36 PM
Dan1953's Avatar
Broke down and had a local car repair shop check the fuel pump and they found low pressure. 3 hours of labor at $89, $361 pump and $45 of shop supplies fixed the problem.
I also had then lube the mid steering shaft that was "clunking" when making a hard turn and the clunk sound is gone.
ps56k
Jul 2, 2013 1:24 PM
timburl
Dec 29, 2011 10:07 AM
bouchmpd
Oct 6, 2009 8:30 PM
Rayzun
Site Feedback
Nov 8, 2007 8:58 AM
