Up & down idle when A/C is on Only.
Old Apr 30, 2009 | 6:22 PM
  #11
15 Year Member
Adding too much can be disasterous. Liquid doesn't compress, therefore you get what's called slugging the compressor and that's just really bad. new2me and in2pro had good advice. Start slow. Let us know how it works out.
Old May 7, 2009 | 10:54 AM
  #12
JCRAMOS's Avatar
Default A/c, idle
Well I got both of my problems corrected with all your help, thanks, I clean the throttle body and I fill the a/c with r134 but I over filled it and it started making some weird sounds so I finally got a better gauge and I let some r134 drain out and all is o.k. for now.
Old May 7, 2009 | 10:57 AM
  #13
JCRAMOS's Avatar
Default Oil Weith??
What is the recommended oil weigh I should be using for my miles (98,000) ???
Old May 7, 2009 | 9:18 PM
  #14
15 Year Member
Same weight as originally recommended. Might consider switching to one of the new high mileage oils if your consumption is up.
Old Jul 22, 2019 | 2:42 PM
  #15
ronand2020's Avatar
Check the belt idler pulley and make sure it’s not too loose
Old Oct 1, 2019 | 12:13 PM
  #16
Christopher Lonske's Avatar
Originally Posted by JCRAMOS
Hi, I have a 03 Tahoe that is giving me problems when I turn on my A/C the engine start to idle up and down this would stop if turn off the A/C, also the A/C some times blows hot air when I have the rough idle issues, I have 95,000 miles on it I have not re-filled new refrigerant. Anyone knows what is going???
I know its 10yrs later...
My 2003 Taurus did this.
It ended up being an air leak in the throttle position sensor.
Melody Smith Arquillo
Dec 3, 2012 12:48 PM
Georgiaboy04
Jul 1, 2012 12:56 PM
dtachia
Apr 23, 2011 12:55 AM
chuck5001
Mar 20, 2010 8:34 PM
