Used EBCM Programming
Old Nov 12, 2017 | 7:38 PM
4wheelsteel's Avatar
Default Used EBCM Programming
My EBCM in my 2006 Z71 Suburban has failed. Rather than pay the huge sum for a new one I figured i'd take my luck with a used one on ebay. Will it need to be programmed as well? Or is that only needed with new ones? Also I have an actron CP9680 can you program it with that, from what Ive read so far youre just programming tire size.
Old Nov 12, 2017 | 8:36 PM
kevinkpk's Avatar
You might try ebay with the same generic suburban. Then get specific with an 06 suburban Z71 that can program with your vin.
Old Nov 12, 2017 | 10:41 PM
true programming requires connection to a gm server.
tire size selection can be done with a scan tool....this is done to correct the speedo. this is not programming a module.
the used ebcm; it may plug in and work but to get it the original factory programming your truck was built with would require a dealer. Cost would be around 1 hour labour time.
Old Nov 13, 2017 | 7:41 AM
Thanks for all of the quick reply’s guys. I’ll call my local Chevy dealer and see what they’ll want to do it.
