Vibration & drone problem
Old Nov 6, 2014 | 1:14 PM
atceltic's Avatar
Question Vibration & drone problem
Hello, My ride is a 08 LT with the 5.3L 4x4. wit 120,000 miles on it. Now when I drive between 70 and 75 it drones and vibrates. I have had a mechanic check it out and he thinks it is in the drivetrain and not the wheels/tires & saying it will take some time to figure out exactly what the problem is. So, has anyone here know anything about this or have had the same problem with their vehicle. Thx.
Old Nov 7, 2014 | 7:22 AM
SabrToothSqrl's Avatar
when I read drone problem, I thought something out of terminator.
Well, anything that spins could be causing it.
Easiest thing might be to rotate the tires and see what impact that has.
when were the tires last replaced? did you throw a wheel weight?
Old Nov 10, 2014 | 9:29 AM
atceltic's Avatar
Tires are brand new and have been checked out about 3 times 2 by firestone and 1 by my mechanic. My mechanic is going to place the truck on a lift and run it up to the speed it is vibrating and making a droning ( LOL I thought someone might say something about that word.) noise. thx for the reply.
Old Nov 24, 2014 | 11:47 AM
{tpc}'s Avatar
I had a very similar problem when I first got my truck. I think it was at a lower speed, but it was specific...between like 60-65 mph. It's old and the tires, while still having tread were (are) nearing the end of their usefulness. I took it to the dealer, told them to strip off all the old weights and re-balance the tires.
After that, the vibration went away.
Just recently however, it has developed a new vibration. This time the range is much more broad and the drone more pronounced at times. After inspecting it on the lift it appears the very rear u-joint on the rear driveshaft needs to be replaced. Front still looks good, but we are going to replace both once the shaft is out. It was very easy to spot, and you could probably climb under the truck without being on a lift and inspect it.
atceltic
Nov 5, 2014 12:46 PM
Aquarius14
May 14, 2008 6:34 AM
jsm
Mar 10, 2008 7:06 PM
71cuda
Feb 18, 2007 11:46 PM
