VIN Codes
Old Jan 13, 2009 | 8:32 AM
CrewCabFan's Avatar
Default VIN Codes
Is there a web site I can go to and put my VIN in and tell me what my truck was built with?
Old Jan 13, 2009 | 11:38 AM
Default RE: VIN Codes
I dont know of a site where you can use the VIN to find the build sheet for your vehicle but you can search the forum for the RPO codes and compare them to the ones on the lable in your glove box.
You can problaby take your VIN to the dealer and they can also provide the info, there are probably some folks on here that work or are certified to access that info also.
EDIT
Here is a link to the RPO codes Dave posted awhile back
https://chevroletforum.com/m_7879/tm.htm
Old Jan 13, 2009 | 5:47 PM
shawnvw's Avatar
Banned
Post you VIN and i'll give you the info.
If you don't want to post it PM it to me
Old Jan 14, 2009 | 8:59 AM
CrewCabFan's Avatar
ORIGINAL: shawnvw
You have PM, thanks.
Old Jan 14, 2009 | 8:56 PM
shawnvw's Avatar
Banned
site wetn down or we just got an update or something and I ahve no PM's in my Inbox....re send it and i'll post your info
Old Jan 15, 2009 | 8:17 AM
CrewCabFan's Avatar
Sent again, thanks.
Old Jan 15, 2009 | 8:26 AM
usmcz71's Avatar
do you mind running my vin? its 2GCEK13TX51350923 Thanks I really appreciate it.
Old Jan 15, 2009 | 5:48 PM
shawnvw's Avatar
Banned
CrewCabFan
VEHICLE BUILD
Merchandising Model : CC10543 -2008 SILVERADO 1500 2WD CREW CAB LT1 Gross Vehicle Weight Rating : 3087 kg (6807 lb) Order Number : MNST4X Build Date : 01/24/2008 Build Plant : 38G43
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker. </B>
OPTION CODES
AJ1 - DEEP TINTED GLASS
AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT FRT PASS
AM1 - MANUAL LUMBAR, DRIVER
AP8 - REMOTE VEHICLE STARTER PREP PKG
AT8 - RESTRAINT CHILD PROVISIONS
AU3 - POWER DOOR LOCKS WITH REMOTE KEYLESS ENTRY
AZ3 - 40/20/40 SPLIT BENCH SEAT
A31 - POWER WINDOWS
A68 - SEAT, 60/40 REAR FOLDING BENCH
B30 - CARPETING, COLOR-KEYED
B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR KEYED FLOOR MATS
B85 - BODY SIDE MOLDING
C49 - ELECTRIC REAR WINDOW DEFOGGER
C5U - GVW RATING - 6,800 LBS
C67 - AIR CONDITIONING, MANUAL
DF5 - ISRV MIRROR W/COMPASS & TEMP
DH6 - LIGHTED VISOR/VANITY MIRRORS
DK8 - DELUXE OVERHEAD CONSOLE
DL3 - OSRV MIRROR W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ, HEAT, TURN SIGNAL (REPLACES STD/PKG MIRROR)
E63 - FLEETSIDE BODY
FE9 - FEDERAL EMISSIONS
GF0 - APPEARANCE PKG
GU6 - REAR AXLE 3.42 RATIO
G80 - LOCKING REAR DIFFERENTIAL
JF3 - 17" BRAKES, DISC/DRUM
JL4 - STABILITRAK-STABILITY CONTROL W/ TRACTION CONTROL SYSTEM
KG3 - 145 AMP ALTERNATOR
KNP - HD AUX TRANS. COOLING SYSTEM
K34 - CRUISE CONTROL
K47 - HIGH CAPACITY AIR CLEANER
LY5 - VORTEC 5.3L V8 GAS ENGINE W/ ACTIVE FUEL MGT TECHNOLOGY
MSL - SILAO, MEXICO PLANT
M30 - 4-SPD AUTOMATIC TRANSMISSION
NP5 - LEATHER WRAPPED STEERING WHEEL
NT8 - EMISSION SYSTEM FEDERAL, TIER
NZ4 - FULL SIZE SPARE WHEEL
PDA - TEXAS EDITION: * VORTEC 5.3L V8 W/ACTIVE FUEL MANAGEMENT * 20" MACHINED ALUMINUM WHEELS (REPLACES STD/OPT WHEELS) * OSRV MIRRORS W/POWER FOLD & ADJ, HEAT, TURN SIGNAL AND DRIVER SIDE AUTO DIMMING * TRAILERING PACKAGE * LOCKING REAR DIFFERENTIAL * CARGO MANAGEMENT SYSTEM P58 - 20" MACHINED ALUMINUM WHEEL (REPLACES STD/OPT WHEEL)
QSS - P275/55R20 BW RADIAL TIRES RAE - CARGO MANAGEMENT SYSTEM ROO - BARS VOMS BAILMENT R6I - TEXAS EDITION PKG DISCOUNT (RESIDENTS OF TX, OK, LA & SELECT COUNTIES OF NM, AR, KS, MO, MS SEE DEALER FOR DETAILS)
R7B - GEOGRAPHIC TRACKING CODE
R9N - PROCESSING CODE
R9Z - POMS EXPEDITE-SOLD ORDERS/TSE SAF - SPARE TIRE LOCK SLM - STOCK ORDERS SSB - PROCESSING OPTION TUF - ORNAMENTATION.TEXAS
T74 - HEADLAMPS
UE1 - 1YR ONSTAR SAFE & SOUND(ASK DLR ABOUT TURN-BY-TURN NAV UPGRADE)
UJ6 - TIRE PRESSURE MONITOR
UQ3 - ENHANCED AUDIO SPEAKERS
US8 - AM/FM STEREO WITH CD/MP3
U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
VB3 - CHROME REAR BUMPER
VG3 - FRONT BUMPER
VH9 - ENVELOPE OWNER INFO MANUAL
VK3 - FRONT LICENSE PLATE MOUNT
VR4 - WEIGHT DISTRIB. PLATFORM HITCH
VT7 - OWNERS MANUAL ENGLISH
VXS - COMPLETE VEHICLE LABEL
V22 - CHROME GRILLE
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
V76 - RECOVERY HOOKS
X88 - CHEVROLET CONVERSION
YD3 - BASE AXLE
YD5 - BASE FRONT SPRING
YD6 - BASE REAR SPRING
YE9 - SILVERADO
ZRS - P265/70R17 SPARE TIRE
ZY1 - SOLID PAINT
Z60 - SUSPENSION PACKAGE
Z82 - HD TRAILERING EQUIPMENT
1LT - SILVERADO LT1 EQUIPMENT GROUP: * POWER LOCKS AND WINDOWS * ISRV MIRROR W/AUTO DIMMING, COMPASS, TEMPERATURE * DUAL PWR HEATED OSRV MIRRORS * CHROME SURROUND GRILLE * BODYSIDE MOLDINGS * LEATHER WRAP STEERING WHEEL * REMOTE KEYLESS ENTRY * ILLUMINATED VANITY MIRRORS
1SZ - OPTION PKG DISCOUNT
19D - EBONY
19I - EBONY
41U - BLACK
6TC - SUSPENSION
7TC - SUSPENSION
Old Jan 15, 2009 | 5:56 PM
shawnvw's Avatar
Banned
usmcz71
VEHICLE BUILD
Merchandising Model : CK15543 -2005 SILVERADO 1500 4WD CREW CAB Z71 Gross Vehicle Weight Rating : 3178 kg (7007 lb) Order Number : JBGVD7 Build Date : 04/29/2005 Build Plant : 25143
OPTION CODES
AG1 - SIX-WAY POWER DRIVER SEAT
AM7 - FOLDING REAR SEAT
AU0 - KEYLESS REMOTE DOOR LOCK
AU3 - POWER DOOR LOCK SYSTEM
A31 - POWER WINDOWS
A95 - UPGRADE TO FRONT LEATHER SEATING SURFACES
B71 - WHEEL FLARES
B85 - BRIGHT BODY SIDE MOLDINGS
CJ3 - AIR COND., DUAL ZONE MANUAL
C5W - 7000 LBS GVW RATING
DK7 - INTERIOR CUSTOM ROOF CONSOLE W/ MAP LIGHTS
DT4 - ASHTRAY MUFFIN
D07 - CUSTOM FRONT FLOOR CONSOLE
EVA - EVAP EMISSION REQUIREMENT
FF6 - TORSION BAR SPRING ADJ. - LH
FF7 - TORSION BAR SPRING ADJ. - RH
GT5 - REAR AXLE - 4.10 RATIO
JF3 - BRAKE VAC POWER
JJG - FRT END SUBASSEMBLY
KUP - THROTTLE CONTROL ELECTRONIC
LM7 - VORTEC 5.3L 295HP IRON BLK V8
NP8 - AUTOTRAC ACTIVE TRANSFER CASE
NU4 - CAL EMISSION SYSTEM, LEV2 PLUS
NZZ - OFF ROAD - SKID PLATES
OSG - OSHAWA ASSEMBLY
PDB - SAFE & SOUND PACKAGE: * AM/FM STEREO W/ 6-DISC CD CHANGER & BOSE SPEAKER SYS. (REPLACES STD/OPT RADIO) * 6-WAY PWR DRIVER BUCKET SEAT * ONSTAR SYSTEM INCLUDES 1 YR SAFE & SOUND * XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INC
PDU - LIGHT DUTY POWER PACKAGE: * VORTEC 5300 V8 SFI GAS ENGINE * HD TRAILERING EQUIPMENT P25
QJM - P265/70R17 OOR WOL TIRES
R5C - TIRE BRAND ALL BRIDGESTONE
R9U - GM ACCESS - AUTOBOOK IDENTIFIER
SLM - STOCK ORDERS
SSB - IDENTIFICATION MODEL
TR3 - CHROME GRILLE
TSM - PROCESSING CODE - SUSPENSION
T96 - FRONT FOG LAMPS
UC6 - AM/FM STEREO W/6-DISC CD CHANGER & BOSE SPEAKER SYSTEM
UE1 - ONSTAR SYSTEM INCLUDES 1 YR SAFE & SOUND
UK3 - REDUNDANT RADIO CONTROLS
UK6 - REAR SEAT AUDIO CONTROLS
UQ7 - BOSE SPEAKER SYSTEM
U2K - XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INCL
VG3 - CHROME FRONT BUMPER
VP6 - NOISE CONTROL
XJM - TIRE FRONT P265/70R17-113S WOL R/PE ST TL OOR
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
YE9 - SILVERADO YF5 - 50-STATE EMISSIONS
YJM - P265/70R17-113S WOL R/PE ST TL OOR
ZJP - SPARE TIRE P265/70R17
ZY1 - SOLID PAINT
Z71 - OFF-ROAD SUSPENSION
1SL - Z71 OFF ROAD PACKAGE INCLUDES: * DEEP TINT GLASS * OFF-ROAD SUSPENSION * HIGH CAPACITY AIR CLEANER * OFF ROAD - SKID PLATES * AUTOTRAC TRANSFER CASE * LOCKING REAR DIFFERENTIAL * FRONT FOG LAMPS * AM/FM STEREO W/CD & CASSETTE * WHEEL FLARES
1SZ - TOTAL POWER PAC SAVINGS
59U - SILVER BIRCH METALLIC
6YT - COMPONENT FRT LH COMPUTER SEL
69I - DK PEWTER INTERIOR TRIM
692 - DARK CHARCOAL
7YT - FRONT SPRING
Old Jan 15, 2009 | 9:21 PM
CrewCabFan's Avatar
Thanks, few more questions. What do these mean.
Would it be possible to add the factor intergrated brake controller?
