Voltage Drop on Highway
Old Nov 22, 2015 | 2:51 PM
Eaglewwit's Avatar
Default Voltage Drop on Highway
I was driving along and noticed the Volt meter had dropped to around 12Vdc, and stayed there for awhile, then went back up to just over 14Vdc. Didn't have any problems and no battery drain after it sat for a few days.
I got home and did some test and the battery Voltage and Alternator Voltage are all good.
Anyone else have this problem? Is it simply the gauge or voltage regulator?
I checked the alternator and it looks to not be original, which is good since the burb has 160k on it.
Old Nov 22, 2015 | 3:35 PM
magician's Avatar
It's normal since the BCM controls most of the voltage from the alternator. Basically the BCM determines when and how much voltage the vehicle needs and that's what your seeing. Also, I wouldn't pay to much attention to the voltage guage, it's reaction time is very slow making it less than accurate. It should be used as an indicator that the charging system is functioning or not at best.
Old Nov 22, 2015 | 8:50 PM
05RedZ71Sub's Avatar
Yep that's normal. My 2013 does the same thing. The alternator shuts down to save fuel and voltage drops to a point and then returns
Old Nov 23, 2015 | 1:30 PM
Eaglewwit's Avatar
I didn't realize they had that technology back in 2005. Isn't it hard on the battery to supply the full load?
Old Nov 23, 2015 | 3:40 PM
magician's Avatar
The hardest thing your battery does is start the truck and it recovers if it's in good condition fairly quickly. A lot of things go into determining battery life cycle but the most important is maintaining an appropriate level of charge and operating temps. 77* is the ideal temp for most flooded cell batteries and at this temp they will last years, above or below and the life cycle is decreased. Charge technology has changed little over the years but battery life has been greatly extended in that same time. The biggest reason your truck stops charging or trickles a charge to the battery is due to mileage, less drag on the engine equals better mileage. Trickle charging just happens to be the best way to charge a battery as well.
Old Nov 23, 2015 | 6:57 PM
Actually correction that is not normal. My 2005 dis not do that. It always stayed at the same level. I thought your truck was newer
