Washer Fluid Leak on my 1999 Burb
Old Aug 8, 2010 | 4:27 PM
tbone510's Avatar
Default Washer Fluid Leak on my 1999 Burb
Well, I hadn't used the washer fluid spray in ages. Literally. So I didn't miss it at first.
Earlier today I tried to use it, I heard the fluid pump going, but no fluid ever arrived. So I first checked that there was fluid in the reservoir, and there didn't seem to be. So I filled it up, and tried again. Heard the pump, but still no fluid. The first thing I thought to check was clogging of the fluid jets, but then I noticed a ton of washer fluid leaking out from under the truck, just behind the driver's side front wheel. Just a shot in the dark, but I'm thinking it's a loose hose or something of that sort? Is this an easy DIY fix? Any advice?
Thanks.
Old Aug 8, 2010 | 4:32 PM
Welcome to the forum
I'd be willing to bet the tank is cracked... or its leaking from the pump housing
Old Aug 8, 2010 | 4:41 PM
tbone510's Avatar
Thanks for the quick reply. It was bubbling a bit around where the tube in which to pour the fluid meets the tank, but no where near enough to produce the volume of fluid that leaked out. I didn't notice the leak til I ran the pump, would this mean it was the pump and not the tank?
Old Aug 8, 2010 | 5:11 PM
Welcome to the forum.
I'd check the hose as they get hard and brittle w/ age especially when they use plastic tubing. Don't ask me how I know.
best way to tell is to get the tank out, if I recall you can access it by removing the aux battery tray....
Old Aug 8, 2010 | 8:12 PM
attached remove and install from manual
73shark
Sep 17, 2008 8:09 PM
Thadeus13
Mar 21, 2008 12:45 PM
johnboy
Dec 3, 2007 7:52 PM
bigtim
Feb 7, 2007 8:51 PM
