Washer Fluid Line Broke
Old Apr 3, 2014 | 9:05 AM
bradm's Avatar
Default Washer Fluid Line Broke
Hello,
I kept getting low washer fluid alert, and indeed it all drains out after a while. Dealership checked it and said couldn't find a problem. Finally I saw it draining one day and found the line break in the rear driver's side just before the bumper.
What would you suggest as a way to fix this line? If I cut back both ends a ways (removing the "coupling", if that's all it is), how do I splice a new tubing properly? I assume I can get new tubing at Lowes but any links on repairing it correctly?
See attached for 2008 Suburban.
Thanks in advance!
Old Apr 8, 2014 | 2:01 PM
mulmur1's Avatar
It is unfortunate that your dealer was not able to find the problem with your washer fluid line. It is nice that you found it.
It would be best to go to your local auto parts store, NAPA, O'Reilly, etc. They should stock replacement plastic line that you can use to repair the problem. When you go, please take a small section of line to match up. Lowes or other big box home improvement stores will stock water line which will work, but may not last as long in the harsh automotive environment.
Please try and cut back the line well into the good line. Your auto parts store should have fittings that will allow you to replace a section. These connectors will have barb fittings that will go into each line. One the line is repaired, have someone activate the washer pump and check for leaks.
Good luck with the repair.
73shark
Sep 17, 2008 8:09 PM
Thadeus13
Mar 21, 2008 12:45 PM
johnboy
Dec 3, 2007 7:52 PM
bigtim
Feb 7, 2007 8:51 PM
