What is my towing capacity?
Old Jul 22, 2017 | 6:29 PM
Rusted1's Avatar
Default What is my towing capacity?
What is the towing capacity of my 1998 chevy tahoe LT 4dr,2wd, with a tow package?...I have heard it's 6000, 6500, and 7000, mostly 7000lbs. Also can I tow in overdrive on flat surfaces at 55 -60 mph?
Old Jul 23, 2017 | 9:04 AM
kevinkpk's Avatar
Look at the sticker on the driver door. Suburban 1/2 ton is 6500
Old Jul 23, 2017 | 8:05 PM
or the owners manual...all depends on the engine, trans, differential, drive configuration 4x2, chassis package, tow package.
as for towing in overdrive...depends on the strength of the applied clutches...if a band is used in od as the holding member, I wouldn't. the main purpose for cancelling overdrive is to reduce constant shifting and the heat build up associated with it. Maybe someone familiar with your trans can give you a better answer.
