What size sway bar bushings????
I have a 2003 1500 Suburban 4WD. Wanting to replace the worn out sway bar bushings. Bar measures 1.33 in diameter next to the bushings.
I know the new bushings should be smaller than 1.33 but exactly what size should they be???
Thanks
Vic
Thanks
Vic
The stock is 1-1/4 but depending on the setup you have they could be 1-3/16 are you doing the front or rear as they are different sizes I believe...
Have you checked Rock Auto to see what is recommended for your vehicle?
Outcastz89
October 30th, 2008 11:08 AM
