Will oil pressure switch/sensor stop truck from starting? no crank 1999 vortec 5.7
Old Oct 15, 2016 | 9:48 PM
Chuck C.'s Avatar
Default Will oil pressure switch/sensor stop truck from starting? no crank 1999 vortec 5.7
I just swapped in a 5.7 vortec into my 1999 Tahoe. The new motor had a 3 pin oil sensor plug.
The one on my cars factory harness has 1 pin. I went out and bought a 1 pin and installed it into motor its a bwd sensor not ac delco. When i went to start truck I get nothing but lights come on and gauges work but no crank no start. The s terminal on the starter is not getting power from ignition switch.
The oil gauge on the dash reads 0 when the key is in the off position and when i turn the key forward.
When I turn the key forward and then back to the off position the gauge will move up to about 20 psi.
Old Oct 16, 2016 | 6:59 AM
a55bruce's Avatar
Not the oil pressure switch, but the transmission selector switch (neutral/park) will keep the engine from cranking.
Also check the....
IGN A fuse (under the hood fuse block) ,
CRANK fuse (instrument panel fuse block),
STARTER RELAY (under the hood fuse block)
Old Oct 16, 2016 | 9:13 AM
Chuck C.'s Avatar
Thanks ! I'll double check those fuses again. I haven't checked the ignition fuse so I'll do that today . It be weird if the nuetral safety switch went out since it was last driven but anything is possible .
