Window Regulator 01 burban
Very easy to do, once you get the panel off all your going to need is some tape to hold the window up and a 10mm socket or wrench to remove the 6 or 8 bolts on the frame I can't remember how many and the 2 on the window. It will collapse so you can pull it out and then slip the new one in line up and install all the bolts losly then once all are in tighten them up and reinstall the door panel.
david_159753
February 10th, 2008 11:16 PM
lacelles
July 12th, 2007 10:35 AM
ake11
June 29th, 2007 1:36 PM
