Window Regulator 01 burban
Old Feb 5, 2013 | 9:29 PM
Ermartinez11's Avatar
Default Window Regulator 01 burban
Difficult to install?
Just bought the replacement. Putting it in tomorrow.
Old Feb 6, 2013 | 9:23 PM
Ghetto Burb's Avatar
Very easy to do, once you get the panel off all your going to need is some tape to hold the window up and a 10mm socket or wrench to remove the 6 or 8 bolts on the frame I can't remember how many and the 2 on the window. It will collapse so you can pull it out and then slip the new one in line up and install all the bolts losly then once all are in tighten them up and reinstall the door panel.
Old Feb 7, 2013 | 5:26 PM
Got it in, took about 2 hours. just cause i was taking my time. thanks
YosSam15
Aug 13, 2023 10:33 PM
bsr2002
Jun 10, 2010 11:04 PM
david_159753
Feb 10, 2008 11:16 PM
ake11
Jun 29, 2007 1:36 PM
