Wipers
Old Jun 23, 2021 | 1:06 PM
buttanic's Avatar
Default Wipers
Got another screwing from GM along with the cracked dash and AFM oil consumption issue.
I needed to change the wiper blades on my 07 Suburban, it uses a pinch type attachment to attach the blade to the arm. It is getting harder to find that type blade, the J hook is the most common type now.
Low and behold there was a technical service bulletin to replace the pinch arms on 07 and 08 years with 09 and later J hook arms. Who ever got notified about the bulletin, not me.
Subject: Windshield Wiper Streak at Low Vehicle Speeds (Replace Windshield Wipers and Arms) #07-08-43-010 - (12/05/2007)
Models: 2007-2008 Cadillac Escalade, Escalade ESV, Escalade EXT
2007-2008 Chevrolet Avalanche, Suburban, Tahoe*
2007-2008 GMC Denali, Denali XL, Yukon, Yukon XL
*Excludes Tahoe Police Package
Condition
Some customers may comment that the windshield wipers streak the windshield and do not clean properly at low vehicle speeds.
Cause
This condition may be caused by low blade pressure to the windshield.
Correction
Replace the wiper blades with conventional styled blades. The wiper arms will also have to be replaced.
Open the hood.
Remove the windshield wiper arm finish cap. Use a small flat-bladed tool to remove the finish cap.
Remove the wiper arm nut and disconnect the washer hose.
Remove the wiper arm using the J 39637 - Wiper Arm Puller.
Install the wiper to the wiper arm and remove the plastic union from the new assembly.
Install the wiper arm assembly to the vehicle. Line up and hold the blade to the vertical black bar target mark located at the lower center portion of the windshield and tighten the nut.
Tighten
Tighten the nut to 30 N·m (22 lb ft).
Install the windshield washer hose.
Install the finish cap.
Close the hood.
Parts Information
Part Number
Description
Qty
25879117
Wiper Arm-Left
Wiper Arm-Right
Wiper blade
Old Jun 30, 2021 | 1:35 AM
KChevy75's Avatar
I installed michelin hybrid wiper blades on my 2007 Suburban that fit the original wiper arms. They looks like beam but are just a conventional blade with a cover over it. I removed the cover because it was tapping on the windshield when it flipped. I'll be installing the new wiper arms in the near future!
Looks like the new part numbers are 22917501 and 22917502.
marcochevyman
Apr 4, 2018 8:25 AM
rruelas
Feb 3, 2011 10:10 PM
sasboe
Jan 2, 2010 12:14 AM
73shark
Jan 11, 2009 4:49 PM
