Wiring an Overhead Monitor on 2007 Tahoe..help?
Old April 9th, 2012 | 10:05 AM
Davidc21a's Avatar
Default Wiring an Overhead Monitor on 2007 Tahoe..help?
Hi guys,
Was wondering if I could get some help with wiring an overhead monitor I purchased for my Tahoe. I need help with wiring. I know i should ground the monitor to a bolt under the passenger seat. But......
How does the rear overhead console come off?
Where can I pull the Red ACC power from?
Where do I connect the yellow +12 VDC battery to?
Finally, which wire do I connect to the dome light positive or negative?
Any help would be greatly appreciated.
Old April 9th, 2012 | 10:54 AM
The red power wire should be connected to a 12 volt power source that switches on and off with the key. The 12 volt yellow wire connects to a 12 volt power source that is on all the time so the monitor maintains it's memory all the time. I don't know why you connect to the dome light unless the monitor has some kind of dimmer???
Old April 9th, 2012 | 8:14 PM
Davidc21a's Avatar
Old Chevy can I just run and connect this wires to the back of the radio? Will the power be sufficient?
Old April 9th, 2012 | 10:55 PM
You should be ok. The new LCD monitors don't draw much power.
strannik999
March 15th, 2015 3:50 PM
JohnAndrew
December 15th, 2012 1:27 AM
rehills
Astro
October 31st, 2012 3:56 PM
gmtchsctt
September 4th, 2010 10:30 PM
dailynhtly
December 22nd, 2007 3:17 AM
