XM option disappeared on my factory radio
Old May 20, 2026 | 10:13 AM
Bill Weir's Avatar
Default XM option disappeared on my factory radio
We recently added Sirius to our 2006 Suburban 2500 LT. It worked fine for a couple weeks, then disappeared the other day. Now the radio cycles through AM, FM1 and FM2 but no longer shows sat as an option. The vehicle is an LT with the optional OEM XM/NAV radio head unit.
Old May 20, 2026 | 10:21 AM
Welcome from Florida. Try this, disconnect the negative battery cable for ten minutes, reconnect and see what happens. If that doesn't work call serius radio and see if they can connect to your radio.
Old May 20, 2026 | 11:30 AM
Bill Weir's Avatar
Thanks - will try that. Sirius can't reflash unless I set the radio to Sat....which doesn't show.
Old May 20, 2026 | 2:59 PM
Bill Weir's Avatar
Update: unhooked the battery ( and cleaned a really corroded terminal), hooked it back up, XM is back!! BUT....now the truck won't start....clicks, but no start. BAttery is fully charged. UGH!!!
Old May 20, 2026 | 3:32 PM
Rednucleus's Avatar
I would unhook & thoroughly clean both pos & neg terminals and try again. If still just a click maybe try jump with another vehicle
Stillwater1136
Trax
Oct 22, 2020 6:00 AM
bha19
Oct 13, 2012 7:13 PM
sburrer
Dec 18, 2011 1:32 PM
kweise
Mar 14, 2008 8:06 AM
