Yet Another Key Fob Programming Question
Old Dec 5, 2016 | 4:39 AM
jthorusen's Avatar
Default Yet Another Key Fob Programming Question
Greetings to the Forum:
I recently purchased a used 2005 Suburban LT 1500. The vehicle came with only one key and key fob, the latter being a GM original marked with a "2" on the back.
I purchased an after-market key fob from the internet and proceeded to do the "programming" steps. The after-market key programmed just fine and works well. However, the vehicle will not respond to the original GM key fob. I had replaced the battery in the original GM key fob and it was working well until I tried to program the new after-market key fob. Since the procedure erases all previous recognition codes, I was not surprised that the GM fob no longer functioned. What was surprising is that the vehicle recognized the new fob but refused to recognized the GM original.
I took a look at both fobs with my spectrum analyzer and both fobs output a data burst at about 315 MHz after the lock and unlock buttons are held down for ten to fifteen seconds, as per instructions.
Has anyone ever run into a problem with re-recognizing an original GM fob? Does this require dealer programming for a 2005 Suburban LT? (If so, it is cheaper by far to buy a second after-market fob than to pay the local Chevy dealer's price for programming.)
Thanks for any input.
Regards,
Jim T.
Old Dec 5, 2016 | 1:41 PM
repeat the programming again but program the factory fob first...see what happens.
Old Dec 6, 2016 | 12:40 PM
jthorusen's Avatar
Thank You very much, Tech2. Your suggestion did the trick. Apparently, the rule of thumb when using a combination of GM and aftermarket fobs is: Program the GM fob first.
Thanks again,
Jim T.
