05/06 Tahoe/Suburban/Avalanche ABS module electrical connector problem
Old Dec 9, 2016 | 7:52 AM
jamiew66's Avatar
Default 05/06 Tahoe/Suburban/Avalanche ABS module electrical connector problem
Hi,
I have a 2006 Tahoe that I need to remove the ABS control Module. The 4 torx screws on top are loose however I'm having a problem releasing the electrical connector. I did my 2001 GMC Sierra last year and it had 2 connectors, they were easy. However this Tahoe has just 1 large connector, it has a small plastic handle that releases by pressing in with a screwdriver. I have the handle released and when I try to move it across the bottom of the connector it only goes about 1/3 of the way and then stops. It looks like it should go all the way but stops at about 1/3 of the way. I don't want to force it but at this point I'm not sure how to fully release it.
I have searched the internet with no luck in finding any info at all.
Jamie
Old Dec 9, 2016 | 8:26 AM
spray some penetrating fluid on the sliding part of the connector. Work it back and forth until it releases.
Old Dec 9, 2016 | 11:21 AM
jamiew66's Avatar
Smile
Thank you Tech2, it worked a charm. I had never come across that type before and didn't want to use any brute force and regret it.
Jamie
