'07 Suburban Hard Starting on First Attempt
Old Aug 8, 2019 | 3:21 PM
  #11
I bought the check valve on Ebay. I put it on the feed line as close to the tank as I could get it. Make sure it is rated for gasoline and the hoses to connect it are rated gasoline for fuel injection.
Old Oct 4, 2020 | 4:35 PM
  #12
cliffbry@hotmail.com's Avatar
Default Don’t install check valve in a non fuel return system (ie 2008 5.3 vin J).
Originally Posted by pjrxj
I know this is an old post but I'm having the same problem in my 14 Suburban. Exactly how did you fix it? Thanks.
I installed a check valve on a 2008 Suburban 5.3 vin J and found that the fuel rails will continue to build fuel pressure after engine is shut off due to heat absorption. This system is a non fuel return design and will not start with excessive fuel pressure. My fuel pressure gauge read 100+psi (pegged the fuel gauge).
I removed the check valve and installed a Bosch fuel pump to eliminate the hard start problem. The pump that was causing the hard start was an aftermarket Airtex pump module assembly. I bench tested the new Bosch pump. Blowing (with mouth) air backward through fuel line and no air can go through but I could blow back through the Airtex pump.
