1996 Suburban [K1500 LT 5.7L] Interior Lighting HELP
Old Nov 24, 2016 | 7:14 AM
Howard Fupp's Avatar
Default 1996 Suburban [K1500 LT 5.7L] Interior Lighting HELP
Hello - unsure if this is correct location for post. However, attempting to replace 2 interior bulbs. One is the 'footlight'/courtesy light on passenger side under right side of glove box. Have located the bulb 'inside' a plastic cylindrical housing w/a black wiring connector very reachable from 'top'. Bulb, itself, is 'reachable' (but difficult) from bottom inside plastic cylindrical housing. How do I remove either/both to replace the bulb ? I am guessing that the black bulb jack may possibly twist out or maybe just pull straight up from the TOP -- however, I don't wanna attempt and risk breaking it BEFORE checking here w/you people. ALSO, while I have radio out, I need to replace the bulb BEHIND the fan control switch
just below & on left side where radio was installed. I believe there are 3 bulbs in the heater control switches - 1 for each of the 3 controls. The center (temperature) and right (vent selector switch) bulbs are both OK. Could someone show either a picture or diagram as to exact location for that left side bulb and ITS replacement procedure ? Thanks for help.
