1999 suburban K1500 stuck in OD
Old Aug 15, 2019 | 10:25 PM
1999burb's Avatar
Newly Registered
Default 1999 suburban K1500 stuck in OD
Hello All,
i’m new Here and was hoping I can get some help with a shifting problem I’m having today. Last week I notice some hard shifting between gears one and two. So I figured it’s got 201k on it, maybe I should replace them. So I changed out the tranny oil,filter and both shift solenoids and made triple sure the fluid levels were correct. Now I during the test drive I notice it goes and drives in reverse just fine. However when I go to drive I notice that it very sluggish. Not slipping but as if I’m starting off in 2nd or even 3rd gear. I just went 100 yards down the street and reversed back to my drive way. I also noticed my instrument cluster immediately start misbehaving. The fuel gauge was doing complete circles, no rpm gauge or speedo. The oil pressure was working though...lastly there is a check light that says “check instrument gauges”? Also there is no red indicator that shows what gear you are in. Any thoughts?
ps I used dextron iv
cory74700
Dec 13, 2019 9:38 AM
PapaHepcat
Sep 26, 2019 3:35 PM
micahs20
Oct 18, 2018 10:50 AM
3blacksilverados
Jan 1, 2016 1:47 PM
cory74700
Apr 22, 2014 10:09 PM
