2 Random Wires - No lights or sensors malfunctioning
Old Jul 13, 2016 | 9:19 AM
Pnealis's Avatar
Default 2 Random Wires - No lights or sensors malfunctioning
Team,
The other day I just happened to notice when I was washing my tires a red and black wire hanging inside the driver's side wheel well. I it has a "bolt down" tip to it, so it does not plug into anything. I tracked it back to the conduit below the brake fluid reservoir. As I said in the headline, I do not have any lights on the dash or any sensors going off. What could it be? Pictures attached. Nothing aftermarket on the car accept for slightly oversized tires.
I couldnt post the photos. They are in my drop box link. (Please let me know if someone suggest a better way to post the photo).
https://www.dropbox.com/sh/2skzgj4nc...nfT8krPta?dl=0
Thanks
Old Jul 13, 2016 | 9:10 PM
Welcome to the forum.
What year is it and did you get it new or used?
Old Jul 14, 2016 | 5:59 AM
Pnealis's Avatar
I purchased the vehicle used a little over a year and a half ago.
Old Jul 14, 2016 | 2:13 PM
The red wire with black stripe and a terminal log on the end terminates on a big lug stud on the top front of the fuse box on top of the left fender. Since it is picking up 12 volts there, something in your truck is not getting 12 volts anymore.
Old Jul 17, 2016 | 8:48 PM
Pnealis's Avatar
Thanks I have mounted it back to the fuse box. I have not noticed any differences, but as I said their were no lights on to begin with. Did you notice the other wire not attached in the last photo, the one where you can see the fuse box? It was in the conduit between the fuse box and the outer wall? Also not connected to anything, but no slack to move it anywhere.
Old Jul 17, 2016 | 9:12 PM
I will have to take a look and see if mine has one also.
