Old Aug 7, 2015, 7:36 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
2001 interior lights
Old Nov 25, 2011 | 9:25 PM
htepainting's Avatar
Default 2001 interior lights
I have an 01 Suburban. The interior dome lights don't work when the doors open nor when the dome override switch is pushed. Also when you roll the dimmer switch all the way up the lights do no come either. Please help.
Old Nov 25, 2011 | 9:26 PM
Fuses are not blown, that I know of. What are my next steps?
Old Nov 25, 2011 | 9:40 PM
EinST's Avatar
Welcome to the forum. Check the 15A CTSY LP fuse in the underhood junction block. There should be battery voltage. After that, try replacing the INADV PWR relay and CTSY LP relay in the I/P fuse block. Either one can knock out the courtesy lighting.
Old Apr 8, 2012 | 8:34 PM
Rice80's Avatar
What's the relay # and if s under the hood
Old Apr 8, 2012 | 8:46 PM
Rice80's Avatar
I have a2001suburban 2500 the I don't have any lihts indie,check all the feusess and thy good can some one please help me with this matter?thank you
Old Apr 9, 2012 | 9:40 AM
On my 99, I have to roll the dimmer switch up and down real quick for a while before the lights come on. Over time the switch became erratic and doesn't always work. Check the switch.
Old Apr 9, 2012 | 5:55 PM
EinST's Avatar
On the 2001 Suburban, the INADV PWR relay and CTSY LP relay are located in the center I/P fuse block (underneath the instrument panel, to the left of the steering column).
nysmedic
May 13, 2013 10:04 PM
jamesq
Nov 2, 2010 6:02 AM
skdevore
Aug 26, 2009 10:18 PM
crete110
Aug 11, 2009 10:45 AM
