2005 Suburban Smoking - Vortec 5.3L
Old Feb 22, 2017 | 4:33 PM
Bimmerknut's Avatar
Default 2005 Suburban Smoking - Vortec 5.3L
Almost every time I start the engine I get a large blue cloud of smoke and then it's gone. It doesn't smoke while driving at all, even if I get on it entering the highway.
It goes through oil at the rate of about 2 1/2 quarts every 4-5 weeks, though there is not much on the driveway. It's only got about 180K on it and the engine runs great.
What am I looking at to fix this? Head gasket? or more? If I can fix this myself, it'll save me getting rid of it.
If needed I can post a video...
Thanks folks!
Old Feb 23, 2017 | 6:42 AM
kevinkpk's Avatar
It's probably a valve seal leaking. You will have to run a compression check to make sure it isn't rings. My bet valve seal time
Old Feb 23, 2017 | 8:39 AM
does the spark plug center electrode have ash deposits?
Old Feb 24, 2017 | 10:03 AM
ebacon's Avatar
Check the calve cover. I had a similar problem thinking it was a head gasket but it turns out the valve cover has a baffle that goes bad and sucks oil in via the pcv
Old Feb 24, 2017 | 8:33 PM
what year truck was yours that had this problem
Old Feb 24, 2017 | 9:18 PM
ebacon's Avatar
2006 Yukon and 2003 suburban
