2007 Suburban Cranks, No Start even after many new parts. Help
Old Sep 16, 2018 | 1:52 PM
andrisport's Avatar
Default 2007 Suburban Cranks, No Start even after many new parts. Help
Hi, Yall. Need Help with recently purchased non running 2007 Suburban. So, New battery, spark plugs, spark plug wires, ignition coils. There is solid spark when cranking the engine( at least at one cylinder ). Then... New fuel pump, injectors cleaned, fuel pressure checked (a little over 50psi while cranking). Fuel pump relay is good, injectors fuse is good. Doesn't even start with starting fluid after all. Any ideas? TIA
Old Sep 16, 2018 | 2:13 PM
kevinkpk's Avatar
Can you give a little history of the vehicle?
Old Sep 16, 2018 | 2:26 PM
andrisport's Avatar
don't know the history of the vehicle. i was reading other forums and one guy said timming chain could stretch and TDC is messed up. BTW the mileage is 230K.
Old Sep 16, 2018 | 8:33 PM
Welcome to the forum.
Need to check compression on all 8 cylinders. The GMT900 had some severe issues with the AFM causing failed lifters. If that's the case, it's an expensive repair and I hope you got a really good deal on this truck.
