2014 suburban electrical issue- battery drains in 48 hours??any ideas/hints/solutions
Old Jun 13, 2017 | 4:31 PM
Texas556's Avatar
Default 2014 suburban electrical issue- battery drains in 48 hours??any ideas/hints/solutions
For one year if I don't use the vehicle for 2 days, battery dies. 3 New batteries, amp meter indicates 4.6 amp drain (between + cable and battery terminal.
Any ideas/hints/solutions???
Old Jun 13, 2017 | 7:46 PM
that is a huge draw. normal draw should probably be 20miliamps after all the modules enter sleep mode.
realize that if you are not using a battery isolator when measuring the way you are...the initial connection will wake every module and you will have a big draw until the modules enter sleep mode. this may take 5 to 20 minutes.
any aftermarket stuff on the vehicle? List anything that is connected to the vehicle electrical system...even at the power outlets.
