95 Suburban headlights, low off when bright on
Old Jan 7, 2012 | 9:46 PM
white95suburban's Avatar
Default 95 Suburban headlights, low off when bright on
This post concerns a 1995 Suburban. When you switch the high beams on, the low beams shut off. So it is a toggle between the two sets of lights. I assume this is the way the car was designed.
I would like to have the low beams stay on while the high beams are on. Does anyone know of a safe modification to make it work this way?
I just put in HID lamps and transformers for both pairs of lights, so power and blowing fuses should not (hopefully) be an issue.
Any suggestions appreciated.
Old Jan 23, 2012 | 11:03 PM
burb-guy's Avatar
There is a way to do it, or you can purchase a pre-made harness from lmctruck.com. If you decide to do it, you will need a relay to send power to the low beams when the high beams are on and a diode to keep from back-feeding the relay when the low beams are on.
lutherbeau
Camaro
Nov 8, 2012 2:01 AM
mykids08
Oct 24, 2008 1:18 AM
FredChevy24
Mar 26, 2008 2:38 PM
donnyhinds
Feb 19, 2008 11:21 PM
racerad
Mar 15, 2007 6:55 PM
