Broken Intake Manifold Bolt
Old Jun 25, 2016 | 8:08 PM
threexd's Avatar
Default Broken Intake Manifold Bolt
So I'm putting my intake manifold back on after replacing knock sensors and broke the # 1 torque position bolt. Got an extractor to try and get it out and the extractor bit broke off in the hole that was drilled into the broken bolt. How do I get this mess fixed?
Old Jun 25, 2016 | 10:34 PM
cleveland63b's Avatar
first off get your torque wrench calibrated or use one if you weren't. Second that can turn into a nightmare sometimes since the extractors are usually very hard metal. Do you have a way to take a picture to see exactly where everything is?
Old Jun 26, 2016 | 12:35 AM
threexd's Avatar
I'll take a picture in the morning. I was using a torque wrench but wasn't paying attention and set my wrench to ft/lbs instead of in/lbs. Painful and potentially expensive lesson...I know. Thanks for the reply.
Old Jun 26, 2016 | 8:44 AM
threexd's Avatar
Pictures attached. Any ideas? The extractor bit was a Ryobi bit if it makes any difference.
Old Jun 26, 2016 | 8:53 AM
try to place a nut over the broken bolt and weld through the hole in the nut...build up a bead to join the broken bolt and nut. put a water soaked rag over the open fuel lines.
Old Jun 26, 2016 | 2:06 PM
yea welding something onto it to get leverage looks to be about your only hope without risking damage to the head
