crank posirtion sensor on a 2000 tahoe 5.3
Old Aug 28, 2016 | 10:12 AM
pwcard62's Avatar
Default crank posirtion sensor on a 2000 tahoe 5.3
I changed the crank position sensor on my 2000 chevy tahoe and now the motor turns over but it wont fire. it would start before I replaced sensor
Old Aug 29, 2016 | 1:59 AM
Check the connector plug and make sure that none of the wires came loose or broke. Why did you change it if it was running?
Old Aug 29, 2016 | 2:51 AM
pwcard62's Avatar
I PUT THE OLD ONE BACK IN AND IT STARTED. THE REASON I AM CHANGING IT IS BECAUSE THE TRUCK RANDOMLY CUTS OUT LIKE IT RAN OUT OF GAS. I LET IT SIT FOR 30 min to an hr and it restarts. While I was waiting I checked the fuel psi, it was 50 psi. When I checked the codes, p0335, p0336 & one for the knock sensor.
