Engine Knock
Old Sep 23, 2010 | 9:56 AM
Basshoggin's Avatar
Default Engine Knock
200 Chevy Tahoe 5.3L 167,000 mikes. First startup in the morning I get a knocking sound for about 1 to 1 1/5 min. then it goes away. Your thoughts?
Old Sep 23, 2010 | 11:24 AM
Welcome to the forum,
It would be my guess that its probably lifters that are a bit dry on start up...
make sure you are using a quality oil filter that has a anti drain back (AC Delco preferred)
You could try changing to a blended oil part dino part synthetic for higher mileage engines
Some have had good luck performing an engine flush or using an additive to the oil, thou I prefer not to go this route as good routine maintenance (regular oil changes) should do the same.
Old Sep 24, 2010 | 8:16 AM
Basshoggin's Avatar
Thanks In2Pro I will look at doing this!
Old Dec 23, 2010 | 3:14 PM
Farmer160's Avatar
Default Still knockin?
Basshoggin, were you able to get something remedied with your engine knock? I too have an identical problem with my 2000 suburban with 125,000 miles. Mine started to do it at about 100,000 miles and 8 years old. I have been told that it is a common problem for chevrolet.
Old Feb 4, 2011 | 12:06 PM
ChevyDave007's Avatar
It is very common on the 5.3l. I have read that it comes from the piston skirts. It is normal and very common but doesn't hurt anything although its annoying. Mine has been doing it for more than 50K and hasn't changed.
Old Feb 5, 2011 | 8:10 AM
Basshoggin's Avatar
Thanks ChevyDave007, I guess I will have to live with it... I have 170K on the engine now... Love my Tahoe...
matt21191
Nov 21, 2007 4:17 PM
scoyoc5
Oct 2, 2007 6:42 PM
brudel1
Nov 20, 2006 4:17 PM
lroewer
Oct 24, 2006 8:16 AM
