Lifter? Or camshaft? Or both???
Old Dec 25, 2017 | 10:25 AM
  #11
Kozy's Avatar
Originally Posted by kevinkpk
It does sound like a lifter, however as you increase the rpm, I don't hear the noise follow it.
You don’t hear the noise follow it because I never increased the RPM during the video The noise does definitely speed up with RPMs though.
Old Jan 11, 2018 | 6:27 PM
  #12
Gunner41's Avatar
It sounds like my 7.4. I cant tell which lifter it is??? I did the Marvel Mystery Oil trick. 2 Qts of MMO with 5 Qts oil and ran it for a couple hundred miles and changed the oil. The noise decreased by around 70%. I didn't see much gunk come out of the after change. It still does it when its been parked for a few days without driving it or it gets cold but when it warms up it almost goes away but I still hear it tho.
My worse case scenario is that I have to replace my cam and lifters. Aghhhhh
Old Jun 22, 2018 | 6:02 PM
  #13
Pclown's Avatar
Default About the lifters
Take the value cover off and check your rockers with someone cranking the engine if the arms aren't moving it's definitely a lifter. Or if you can stop the arm from moving with a hammer handle pressed against the rocker arm. And it's always a good thing to check your bearings down below if cam lobe dammage is excessive. I've seen damage in mains and oil pump because of lifters in the dod ls
