Overheating problem.
Old Feb 16, 2020 | 1:45 PM
Turner88's Avatar
Default Overheating problem.
I have a 1995 Chevy Tahoe 5.7L v8 350. I’m having a problem trying to get the heat working. Blend door actuator is good and I just put in a new thermostat. Yesterday I put a new heater control value because the old one broke. I installed it correctly but now no antifreeze is flowing from the radiator which is causing the engine to overheat. I can touch all hoses and they are cold. Nothing is passing through. I didn’t have this problem before. Is the valve faulty or is the vacuum line connected to it causing the problem?
Old Feb 16, 2020 | 5:30 PM
kevinkpk's Avatar
Might be air in the system, loosen the hose clamp around the valve outlet, bleed what air might be in there,
Old Feb 16, 2020 | 11:18 PM
Irish_alley's Avatar
I'm here for the party
like kevin said, could be air or the thermostat could be faulty. if you cant seam to burp the system then take the thermostat out and drop it into some hot (not boiling but close) water on the stove. see if you can see it opening
nlogsdon
Jan 28, 2016 11:15 AM
Ikkarus1
Nov 4, 2014 2:38 PM
comawhite28
Dec 11, 2013 7:45 PM
Reverend Blair
Mar 15, 2013 9:01 AM
dconnell
Dec 30, 2012 1:49 PM
