Please HELP, 2007 Suburban 2500 6.0 Need advise
Old Apr 18, 2017 | 7:17 PM
Anydawg's Avatar
Default Please HELP, 2007 Suburban 2500 6.0 Need advise
So here's my story in a nutshell. I buy and sell all kinds of cars, bikes, book, home goods, you name it I sell it. I have a regular job (custodian) here in NYC. I buy cars at the insurance auction from time to time to keep me busy and out of trouble. Since I just had a newborn my next project was going to be a truck. I found this 2007 2500 6.0. I did a carfax and the last time it was inspected was june 2015 and it had 105k on it. It belonged to the MTA or Nyc transit. The thing looked horrible but it wasn't hit anywhere and it has a Clean NYS title. From photos it looked as if it had a plow on it at one point (only wires left). I had a key CUT
My questions are these. When sourcing parts for this thing (as I belive it's not too far gone) Do I have to start sourcing parts for a 2500? 6.0? Silverado? What fits and what doesn't? I have friends helping me out with this and I'd love to get this going. Anyone with parts PM me if you're within driving distance form NYC then I'm your guy.
Old Apr 18, 2017 | 10:28 PM
intheburbs's Avatar
If you're looking for parts that go in the body of the truck, you can source parts from 1500 or 2500 Burbs. Anything below the body - suspension, frame, powertrain, brakes, etc - you'd have to get from other 2500 Burbs. Unfortunately, the 2500 Burb is not the same as a 2500 HD Sierra or Silverado. It's like a 1500HD - kinda in the middle between the half tons and HD 3/4 ton trucks.
Get a build sheet listing all the RPO codes so you can see what hardware you have.
Here's what I have on my '08 2500 (one thing I can tell you that's different - you have the 4L80E transmission, not the 6L90 that I have)
1SZ
PACKAGE OPTION- (1SZ)
19I
INTERIOR TRIM COLOR (19I)
193
TRIM COMBINATION,BLACK LEATHER (193)
25U
PRIMARY COLOR EXTERIOR, DARK MING BLUE (02) (25U)
3LT
PACKAGE LT OPTION 3 "LT" PKG 3(3LT)
6GK
SPRING COMPTR SELECT FRT LH SUSP(6GK)
7GK
SPRING COMPTR SELECT FRT RH SUSP(7GK)
AG1
ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1)
AG2
ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL MULTI-DIRECTIONAL P/SEAT ADJR(AG2)
AJ1
GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW) DEEP TINTED GLS(AJ1)
AL0
SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR FRT PASS/CHILD PRESENCE DETECTOR INFL REST IND SENSOR(AL0)
AL4
SEAT,REAR,BUCKET RR BKT ST(AL4)
AN3
SEAT FRT, INDIVIDUAL/NON-BKT INDIVIDUAL FRT SEAT(AN3)
AP3
LOCK CONTROL REMOTE, KEYLESS ENTRY, START REMOTE KEYLESS ENTRY & ENGINE START(AP3)
ARS
ADJUSTER RR REAR SEAT, POWER, STOWABLE PWR STOWABLE RR ST ADJ(ARS)
ASF
RESTRAINT ROOF SIDE, LH & RH, INFLATABLE LH & RH ROOF INFLATABLE RESTRAINT(ASF)
AU3
LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
AW2
SEAT REAR 2 PASSENGER 2 PASS REAR SEAT #2(AW2)
AXP
VIN IDENT POSITION, MULTI- PURPOSE VEHICLE MULTI-PURPOSE VEHICLE VIN POSITION(AXP)
A31
WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31)
BVE
STEPS RUNNINGBOARD, SIDE RUNNINGBOARD SIDE STEPS(BVE)
B30
CARPET,FLOOR AND WHEELHOUSE FLR CPT(B30)
B58
COVERING,FLOOR MATS,FRONT AND REAR,CARPETED INSERT CPT INS FLR MATS(B58)
B85
ORNAMENTATION,EXTERIOR,BELT REVEAL MOLDING BELT RVL MLDG(B85)
CE1
WIPER SYSTEM WINDSHIELD, PULSE, MOISTURE SENSITIVE W/S WPR,PULSE MOISTURE SENSITIVE(CE1)
CF5
ROOF,SUN,GLASS SLIDING,ELECTRIC ELEC SUNROOF(GLASS)(CF5)
CJ2
HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT A/C FRT AUTO/AUX CONT(CJ2)
C25
WIPER SYSTEM,REAR WINDOW RR WDO WPR(C25)
C36
HEATER,AUXILIARY AUX HTR,RR(C36)
C49
DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
C6P
GVW RATING 8, 600 LBS/3, 900 KG 8600 LB/3900 KG GVWR(C6P)
C69
AIR CONDITIONER,RR AUX RR AUX A/C(C69)
DCP
PROCESSING DIRECTIONS & CONNECTIONS SERVICE PACKAGE DIRECTIONS & CONNECTIONS SERVICE PKG(DCP)
DF5
MIRROR,INSIDE,REARVIEW,LT SENSITIVE,COMPASS,O/S TEMP DISPLAY I/S REARVIEW MIR W/COMPASS(DF5)
DH6
MIRROR,INSIDE,VISOR VANITY,RH AND LH(ILLUM) ILLUM S/S MIR(DH6)
DK8
CONSOLE ROOF INTERIOR, DELUXE ROOF CONSOLE(DK8)
DL3
MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED POWER FOLDING, TURN SIG IND, LT SENSITIVE, COLOR ELEC HEATED O/S MIR(DL3)
D07
CONSOLE,FRONT COMPARTMENT FLOOR(CUSTOM) CUSTOM F/CMPT FLR CNSL(D07)
E52
BODY EQUIPTMENT ONE PIECE LIFT GATE WITH LIFT GLASS BOD LIFT GATE W/GLASS(E52)
E61
LIFTGATE, POWER PWR LIFTGATE(E61)
FE9
FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
FT2
ARM TORS BAR SPRING ADJ (FT2) ARM LH TORS BAR SPR ADJ(FT2)
FT3
ARM TORS BAR SPRING ADJ (FT3) ARM RH TORS BAR SPR ADJ(FT3)
GT4
AXLE,REAR,3.73 RATIO 3.73R(GT4)
G80
AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
JF4
PEDALS ADJUSTABLE, POWER PWR ADJ PEDALS(JF4)
JH6
BRAKE HYD POWER, 4 WHL DISC, 9,900 LBS BRK HYD PWR DISC(JH6)
JL4
CONTROL ACTIVE BRAKE ACTIVE BRAKE CONTROL(JL4)
KA6
HEATER,RR SEAT REAR SEAT HEATER(KA6)
KC4
COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4)
KG3
GENERATOR 145 AMP 145 AMP(KG3)
KNP
COOLING SYSTEM,TRANSMISSION,HEAVY DUTY HVY DUTY TRANS CLG SYS(KNP)
K34
CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
LY6
ENGINE GAS, 8 CYL, 6.0L, SFI, IRON, GM 6.0-K/N(LY6)
MSL
PLANT CODE SILAO, MEXICO, GM DE MEXICO VIN G-MEXICO PLANT CODE(MSL)
MYD
TRANSMISSION AUTO 6 SPD, HMD, 6L-90 6-SPD A/TRANS(MYD)
NP5
STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
NQH
TRANSFER CASE ACTIVE, TWO SPEED, PUSH BUTTON CONTROL, ALUM SWITCH ACTIVATED 2-SPD TRANSFER CASE(NQH)
NT8
EMISSION SYSTEM FEDERAL, TIER 2 A TIER 2 A FED EMIS(NT8)
NZ3
WHEEL SPARE FULL SIZE, 16" STEEL FULL SIZE SPARE WHL(NZ3)
PCJ
CONTROL - SALES ITEM NO. 103
PDD
CONTROL - SALES ITEM NO. 121
PY0
WHEEL,16 X 6.5,ALUMINUM ALUM WHL(PY0)
QIW
TIRE ALL LT245/75R16/E BW R/PE ST TL OOR 120Q TIRE(QIW)
R9N
CONTROL - SALES ITEM NO. 89
SAF
LOCK SPARE TIRE, HOIST SHAFT SPARE TIRE LOCK HOIST SHF(SAF)
SLM
SALES PROCESSING - STOCK ORDERS
SLT
EQUIPMENT CHEVROLET 'LT' OR GMC 'SLT' SALES PKG 'LT'/'SLT' EQUIPMENT/SALES PKG(SLT)
TL1
GRILLE,SPECIAL SPECIAL GRL(TL1)
T74
HEADLAMPS CONTROL AUTOMATIC, DELAY AUTO HLDP(T74)
T96
LAMP,FRONT FOG FRT FOG LP(T96)
UD7
SENSOR INDICATOR NEAR OBSTACLE DETECTION/REAR PARKING ASSIST RR PARKING ASSIST/OBSTACLE DETECTION SENSOR(UD7)
UE1
COMMUNICATION SYSTEM VEHICLE, G.P.S. 1 GPS 1 VEH COMM SYS(UE1)
UG1
OPENER GARAGE DOOR, UNIVERSAL UNIVERSAL GARAGE DR OPENER(UG1)
UJ6
INDICATOR,LOW TIRE PRESS LOW TIRE PRESSURE IND(UJ6)
UK3
ELECTRONIC SYSTEM,ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3)
UK6
RADIO CONTROL REAR SEAT & EARPHONE JACKS RR ST AUDIO(UK6)
UQA
SPEAKER SYSTEM PREMIUM PERFORMANCE ENHANCED AUDIO PREMIUM SPKR SYSTEM(UQA)
UVB
RADIO AM/FM STEREO, SEEK/SCAN, AUTO TONE, CD, CD-R MP3, DVD, NAV, CLOCK, ETR, RDS STEREO W/CD MP3 DVD & NAV(UVB)
UVC
CAMERA REAR VIEW REAR VIEW CAMERA(UVC)
U2K
DIGITAL AUDIO SYSTEM S-BAND DIGITAL S-BAND AUDIO SYS(U2K)
U42
ENTERTAINMENT SYSTEM REAR SEAT,SINGLE DISPLAY,REM CONTROL W/HEADPHONE ENTERTAINMENT SYS(U42)
U84
ANTENNA BODY SIDE WINDOW, RADIO BODY SIDE WINDOW RADIO ANT(U84)
VFF
VIDEO FORMAT REGION 1, NTSC REGION 1 VIDEO FORMAT(VFF)
VGD
FASCIA FRT, CUSTOM, BODY COLOR BODY COLOR FRT FASCIA(VGD)
VGE
FASCIA RR, CUSTOM, BODY COLOR BODY COLOR RR FASCIA(VGE)
VH9
ENVELOPE,OWNER INFORMATION MANUAL OWNER INFO MAN ENV(VH9)
VK3
LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
VR4
TRAILER HITCH(WEIGHT DISTRIBUTING PLATFORM) EQLZR HITCH(VR4)
VT7
OWNERS MANUAL ENGLISH LANGUAGE ENGLISH LANGUAGE OWNERS MANUAL(VT7)
VXS
VEHICLE - COMPLETE
V1K
BAR LUGGAGE CARRIER,CENTER CROSS LUGGAGE CARRIER(V1K)
V54
CARRIER,ROOF LUGGAGE(PAINTED) PAINTED RF LUGG CARR(V54)
V73
VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
V76
HOOK,FRONT TOW(EXPORT) FRT TOW HOOK(V76)
XA7
WASHER NOZZLES, HEATED, WINDSHIELD HTD W/S NOZ(XA7)
X88
CONVERSION CHEVROLET CHEVROLET(X88)
YD3
AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE FRT AXLE(YD3)
YD5
SPRING,FRONT(BASE EQUIPMENT) FRT SPRING(YD5)
YD6
SPRING,REAR(BASE EQUIPMENT) RR SPRING(YD6)
YE9
CONVENIENCE PKG COMFORT & DECOR LEVEL #3 COMFORT & CONVENIENCE PKG #3(YE9)
ZIZ
TIRE SPARE LT245/75R16/E BW TL ALS 120Q SPARE TIRE(ZIZ)
ZY1
COLOR COMBINATION SOLID SOLID PAINT COMBO(ZY1)
Z82
TRAILERING PACKAGE(SPECIAL)(REESE TYPE HITCH) PROVISION FOR HD TRAILER EQUIP(Z82)
Z85
CHASSIS PACKAGE,INCREASED CAPACITY CHAS PKG(Z85)
Old Apr 19, 2017 | 11:16 AM
Anydawg's Avatar
1SZ
19I
193
25U
3LT
6GK
7GK
AG1
AG2
AJ1
AL0
AL4
AN3
AP3
ARS
ASF
AU3
AW2
AXP
A31
BVE
B30
B58
B85
CE1
CF5
CJ2
C25
C36
C49
C6P
C69
DCP
DF5
DH6
DK8
DL3
D07
E52
E61
FE9
FT2
FT3
GT4
G80
JF4
JH6
JL4
KA6
KC4
KG3
KNP
K34
LY6
MSL
MYD
NP5
NQH
NT8
NZ3
PCJ
PDD
PY0
QIW
R9N
SAF
SLM
SLT
TL1
T74
T96
UD7
UE1
UG1
UJ6
UK3
UK6
UQA
UVB
UVC
U2K
U42
U84
VFF
VGD
VGE
VH9
VK3
VR4
VT7
VXS
VEHICLE - COMPLETE
V1K
V54
V73
V76
XA7
X88
YD3
YD5
YD6
YE9
ZIZ
ZY1
Z82
Z85
Thanks a ton for your information. How about electrical components? I'm thinking fuse block, pcm those things? EBay has a ton of parts, just not sure if they are interchangeable. Should I make a friend at the dealership and ask those questions there as well? Again thanks
Old Apr 19, 2017 | 4:40 PM
intheburbs's Avatar
I'd suggest making friends with the parts guy at the dealership. I'm sure some electrical interchanges with the half-tons, and some don't.
One other big difference - the 3/4 ton uses hydroboost brakes, not vacuum boost like in the half tons.
Old Apr 22, 2017 | 3:19 PM
Anydawg's Avatar
I can't seem to figure out what fuel rail lines fit my vehicle. What parts from other trucks fit mine and injectors? I've got a lot of parts already, but this one is bugging me
Old Apr 22, 2017 | 3:24 PM
Anydawg's Avatar
I can't seem to figure out what fuel rail lines fit my vehicle. What parts from other trucks fit mine and injectors? I've gotten a lot of parts already thanks to your help, but this one is bugging me. I had one ordered on Ebay but they cancelled my order as they didn't have it. It's been difficult trying to find another one (used as junk yards are a bit over what i'd like to pay) in my budget, because as I stated getting all these parts and then I find out something catastrophic is wrong and now I'll be out even more. Again thanks for your help
Last edited by Anydawg; Apr 22, 2017 at 3:32 PM. Reason: Adding, fuel rail line for Evoy is the only thing coming up claiming fitment
Old Apr 23, 2017 | 11:13 PM
intheburbs's Avatar
LY6 engines were used in these platforms (according to Wiki)
Old Apr 26, 2017 | 9:35 AM
Anydawg's Avatar
Default So not much to update but...
I got the fuse block in today and plugged it up and all the light on the dash board lit up. I didn't bother turning the key to crank as its not programmed and I still have no PCM. My wonder is that a carfax report on this car states that it went through a NYS inspection and passed in June of 2015 with 105,555 miles on the dash. The dashboard says 105,864 miles today. Makes me scratch my head because why after only 300 miles did the MTA mechanics start ripping parts out of the the engine. Is that a good sign or bad that there are only 300 miles since last inspected. Thoughts anyone? I should receive the PCM today. After that I'm still going to wait for the coil packs and fuel rail with injectors to try and start it (after getting the key and pcm programmed)
Old May 8, 2017 | 5:49 AM
sfcjones's Avatar
The ECU will have to have the VIN programmed to it. As far as the key, you can program it your self IIRC. There is a procedure you can use. Just go to Youtube and search for it.
you can take that SUV down to Orlando and there is a shop that can put a Duramax LMM motor in it. That would be a sweet Suburban if the it doesn't need much work.
Old May 8, 2017 | 5:58 AM
sfcjones's Avatar
You can also plug the vin in at cheapestgmparts.com and get a list of parts you need at decent prices.
