Tracker 1989-2004
Platform: CAMI (Suzuki)
2000 tracker 2dr antenna
Old Jul 22, 2012 | 10:10 PM
CACTUS24's Avatar
Default 2000 tracker 2dr antenna
Putting a new antenna on my tracker. Has anyone seen where the antenna coax cable connects to the radio extension coax cable. I do not see it, the helm shop manual say it is above the
left side wall junction box area. I looked under the left dash
with a flashlight, i will remove the panel under the steering wheel, maybe i can see into the corner better.
Old Dec 31, 2012 | 4:10 PM
willyworm's Avatar
Default 200 Tracker 2dr antenna
It is located under drivers side dash above fuse panel block. Hope this helps.
Old Jan 12, 2013 | 9:24 AM
CACTUS24's Avatar
Default Tracker Antenna Replacement
I am going to remove the panel under the steering wheel, it has 3 screws that hold on, i think you should be able to see back into the corner better to look for the antenna coax. i will get back to it in April, the Tracker is covered up in the garage, it is still cold in Pennsylvania.
Knat
Feb 7, 2014 7:57 AM
Ninja Viper
Sep 2, 2010 8:00 PM
JenniMac05
Jun 7, 2009 10:19 AM
Paul Monty
Mar 4, 2007 5:16 PM
