Tracker 1989-2004
Platform: CAMI (Suzuki)
2000 tracker park brake
Old Aug 3, 2013 | 2:37 PM
lowflyer1's Avatar
Default 2000 tracker park brake
My park brake lever pulls up and when released there is no resistance to pulling it up again. Brakes drag. It doesn`t get used much in summer. Do the cables usually stick or is it inside the drums where the problem is? It seems to me that the pivots inside the drum may be the culprit. And then how to get the drums off?
Old Aug 11, 2013 | 3:30 PM
CACTUS24's Avatar
Use a 8mm bolt to remove the front rotors and rear drums, you will see
the threaded bolt holes. The 8mm bolt will push off the rotor and drum.
Could be they are rusted up...
hoarybat61
Mar 26, 2013 11:02 AM
hoarybat61
Aug 11, 2012 8:49 AM
seanw
Feb 18, 2010 5:58 PM
Phil Speadahead
Mar 26, 2008 9:07 PM
ubique
Mar 25, 2008 3:31 PM
