Tracker 1989-2004
Platform: CAMI (Suzuki)
2002 tracker 4 cy
Old Jan 19, 2016 | 1:31 PM
Bgist's Avatar
Default 2002 tracker 4 cy
I have a 2002 Chevy tracker 4dr 4cy and need to change out the EGR valve. The issue is the bracket beside and behind the EGR unit that is bolted to the block, blocks you from removing the EGR bolts out. I believe the bracket has to come off or be loosened to remove the 2 bolts from the EGR. The bracket bolt is in a very tough spot under the fuel lines. Is there a way to loosen that bolt of is it standard practice to remove that bracket? The bracket has a wire passing by it from the engine and appears to serve as a resting place to keep wire off engine. ANy help would be appreciated.
