Tracker 1989-2004
Platform: CAMI (Suzuki)
2002 XL7 swap info
Old Jan 21, 2022 | 9:20 AM
gtilford's Avatar
Default 2002 XL7 swap info
I am looking at the front differential out of a 2002 Suzuki XL7 and I am wondering if this will be a direct swap? It has a 2.7 in the engine compartment where mine is the 2.0 in my 2003 4 door tracker. Both are automatics which makes the gears in my diffs the 4.88s if my research is right? Thanks for any info
Old Jan 22, 2022 | 5:56 AM
L84sky's Avatar
The Suzuki parts catalog shows the same part number (27611-82D00) for the front differential housing in the 2002 XL-7 (2.7) and the 2003 (2.0L) Grand Vitara. The pinion and gear set part numbers (27300-60822) are also the same.
Old Jan 22, 2022 | 9:07 AM
gtilford's Avatar
Thanks for the reply but I am asking if it will fit a 2003 Chevy Tracker which has the following part number "Axle Housing - GM (91176630)" now they maybe the same or like other parts between the two manufacturers they maybe different. I am trying to save myself from making a 400 dollar purchase and also the 3 hour drive one way to find out they are just different enough it will not work.
Old Jan 22, 2022 | 11:09 AM
L84sky's Avatar
I don't know. You are much more likely to get a definitive answer on the Gen2 Grand Vitara forum ( https://www.suzuki-forums.com/forums...nd-vitara.211/ ). Those guys do a lot of Tracker/Vitara parts swapping.
Old Jan 22, 2022 | 11:12 AM
gtilford's Avatar
Ok thanks
nic25276
Oct 4, 2016 11:25 AM
Heavychevy2003
Mar 23, 2016 11:02 PM
spade204
Feb 16, 2014 7:24 PM
tim909
Aug 29, 2010 3:45 PM
HP15
Aug 16, 2006 5:40 AM
