Tracker 1989-2004
Platform: CAMI (Suzuki)
99 tracker wont go in gear
Old Feb 10, 2019 | 9:02 AM
swash's Avatar
Default 99 tracker wont go in gear
99 tracker 4 cyl 5 spd wont shift into gear just replaced clutch slave cylinder bled it and it barley pushes the throw out arm also pedal very hard to press could it need a new clutch master cylinder or is the pressure plate cooked thank you
Old Feb 11, 2019 | 7:30 AM
Since the clutch master cylinder is cheaper and much easier to replace, I would try that first.
