Tracker 1989-2004
Platform: CAMI (Suzuki)
Dash and headlights blink... any ideas?
Old Apr 6, 2008 | 4:14 PM
Aaronlane's Avatar
Default Dash and headlights blink... any ideas?
A couple weeks ago the Check Engine Light came on, and then this and the other dash light sbegan to blink everynow and then. It will dim, back, dim, back for about a minute then it will stop for a few minutes. Then dim, back, dim, back... for a couple more minutes then it stops again.
Had the check engine light testedm it came back as the front O2 sensor, but he did not recommend changing out that ($270) part since he doubted it would cause the blinking problem.
Any ideas or suggestions? The alternator, battery, and both O2 sensors tested out just fine in diagnostics.
Thank you!
Old Apr 6, 2008 | 7:07 PM
shawnvw's Avatar
Banned
Default RE: Dash and headlights blink... any ideas?
sounds like a poor ground somehwere
Old Apr 6, 2008 | 8:04 PM
Aaronlane's Avatar
I thought about that too. I removed the groundwire in the engine compartment and brushed it off really well, no change. I checked the battery terminals and tested the battery, also fine.
Anywhere else you can think that I might check?
Old Jun 21, 2008 | 7:10 AM
SurfingfamVA's Avatar
How about checking the alternator - or the tension pulley for the Serp Belt.
Old Jan 28, 2015 | 6:57 PM
99Trackerman's Avatar
Check the emergency brake sensor switch at the base of the e-brake handle for misalignment and possible "bounce". It closes a ground circuit when the handle is pulled, which disables the headlight auto-on circuit. Just something more to check...
Old Feb 13, 2015 | 8:26 AM
thepitchpatch's Avatar
Default Alternator going out
I had this problem - installed new alternator, problem gone. Don't wait till you are stranded somewhere, Alternators can be bought for under $100.00 on eBay brand new!
Old Aug 19, 2015 | 8:20 PM
Sasha Birman's Avatar
Default rear groundwire location
Where is the rear groundwire located?
wjm40a
Uplander
10
Sep 5, 2018 9:35 AM
jtillett
Oct 14, 2011 6:49 PM
boneskeys
Jul 31, 2011 12:27 PM
selth3
Nov 27, 2010 2:42 PM
