Tracker 1989-2004
Platform: CAMI (Suzuki)
Rough Idle after changing spark plugs?
Old May 13, 2014 | 5:35 PM
Lowky's Avatar
Default Rough Idle after changing spark plugs?
Have a '99 Tracker with the 1.6L and have been trying to fix her up (over 160K miles). Timing replaced 5 years ago, belts changed about 2 years ago, & just replaced radiator, thermostat, upper & lower hoses, and new spark plugs. She ran fine the day of (yesterday) but, now is running with a miss, like the timing is off. Thinking this is just an ignition coils and wire set issue, since it's the only thing not change out but, figured better ask anyways. Do I have to reset the computer after a plug change, or should I assume the worst and start looking at the timing if the coils and wires are in good shape? Thanks
Old May 20, 2014 | 8:30 AM
Domino3665's Avatar
Default '99 Tracker spark plugs and computer
I recently replaced the spark plugs on my '99 Tracker. I did not have to reset the vehicle computer. The vehicle runs fine...now. It did not run well immediately after changing the plugs. Having the #2 and #3 spark plug wires reversed will do that, I suppose. I swapped the wires and it runs great. Surprised it even started.
My point is, hopefully it's just a loose connection in your spark plug wires and NOT in the vehicle computer. Good luck.
QUOTE=Lowky;276018]Have a '99 Tracker with the 1.6L and have been trying to fix her up (over 160K miles). Timing replaced 5 years ago, belts changed about 2 years ago, & just replaced radiator, thermostat, upper & lower hoses, and new spark plugs. She ran fine the day of (yesterday) but, now is running with a miss, like the timing is off. Thinking this is just an ignition coils and wire set issue, since it's the only thing not change out but, figured better ask anyways. Do I have to reset the computer after a plug change, or should I assume the worst and start looking at the timing if the coils and wires are in good shape? Thanks[/QUOTE]
Old May 21, 2014 | 12:51 AM
Lowky's Avatar
Well, it turned out to be the Ignition coils, had to replace both to be safe & the plug wires, and the old girl is back up and running again.
ddls1
Jun 25, 2010 6:09 AM
06uplander
Uplander
Jun 2, 2010 7:33 AM
warrior_oh58d
Jan 23, 2009 4:08 PM
Lees2500HD
Jun 29, 2008 6:04 PM
epekarik
Jul 14, 2006 12:51 AM
