Tracker 1989-2004
Platform: CAMI (Suzuki)
Tail light wiring color codes
Old Sep 27, 2021 | 12:45 PM
Dquick48's Avatar
Default Tail light wiring color codes
I am going to use a 1999 tracker as a tow behind my RV. The harness I purchased has wire colors
green
Red
Brown
Yellow
White
The tracker has colors
green w brn stripe
red w yellow stripe
green w white stripe
red
Blk
Can someone please help me match the tracker to the harness?
Old Sep 28, 2021 | 4:56 AM
L84sky's Avatar
This is the trailer lighting connector (C402) color code for my 2001 Tracker.
Old Sep 30, 2021 | 6:59 PM
L84sky's Avatar
Upon further review I realized there is a sixth wire (pin 3) on the factory connector that supplies constant battery voltage.
The factory connector (lower) plugs into my European-to-American turn signal converter box (upper).
Surprisingly the colored wires into the converter box are:
Green
Red
Brown
Yellow
White
The pin-to-pin wire colors are:
Green --- GRN/YEL (right turn)
Red--- GRN/WHT (Stoplight)
Brown--- RED/YEL (tail light)
Yellow--- GRN/RED (left turn)
White--- BLK (ground)
Empty --- GRN (pin 3) battery voltage
99trackerdad
Mar 14, 2014 12:57 PM
TJKashin
Sep 26, 2007 2:15 PM
