Tracker 1989-2004
Platform: CAMI (Suzuki)
trouble with trouble codes 1989 trakker
Old Oct 19, 2018 | 11:38 AM
radioman5959's Avatar
Default trouble with trouble codes 1989 trakker
Issue with o2 sensor and map sensor, when disconnected no fault codes are flashed, the sensors are working as they effect the engine running condition. o2 sensor output OK.
If I disconnect tps or water temp or air temp sensors the codes will appear. Just wonder if there is a fault within the ecm not detecting a disconnect.
Old Oct 20, 2018 | 8:33 PM
L84sky's Avatar
My MAP DTC won't set due to low voltage unless the throttle is held open past 5°.
