'02 TB Horn
![Angry](https://chevroletforum.com/forum/images/icons/icon8.gif)
Just got a 02 TB Std. Horn blew once, with A LOT of effort on the steering wheel center. Now the horn is DOA. That it worked once tells me that the horn itself is good, but that something in the wheel is the problem. Any idea's as I am trying to get the TB thru a Maine inspection for registration, and so far, the horn is the only item that will not pass ? And can someone please tell me where a FUSE BLOCK SCHEMATIC DIAGRAM IS, that shows which fuse controls which system ? Chilton's is totally lacking in this !!!!!!!!!!!!
Found it, but was a bit 'mud'ed up'. But 1 thing DID NOT HAPPEN, that being the horn will not sound without the key in and the engine on. Put the key in and turn the engine on and it's fine. But the horn will not sound UNLESS THE ENGINE IS ACTUALLY ON, the 'Accessories' setting not being sufficient. The why the Manual, nor Chilton's, can explain why. I presume it's a 'nagging issue' with TB's. Thanks !
You previously said that it only works with the engine actually on. This would mean a wiring problem. If this is not the case then it could be the horn button. Be very careful with is as you don't want to damage or set off the air bag.
