02 Trailblazer roof ac vents not working
Any idea what would be causing this and a possible solution would be great. All other heat/ac features/vents work, with the exception of the roof vents. Thanks.
RE: 02 Trailblazer roof ac vents not working
Have you check all your fuses? If there is no fuse for it, check the ground. If not the ground, either the motor is burned up in the fan or the switch is messed up. Alternatively, if it is equipped with a motor run capacitor ora fan relay, thenthat may be your problem
kawi
September 19th, 2016 12:13 PM
osbornesd714
January 17th, 2014 11:26 AM
cjdavis618
October 18th, 2012 10:11 AM
