TrailBlazer 2002-2009
02 Trailblazer roof ac vents not working
Old Jun 1, 2008 | 3:28 PM
scarr133's Avatar
Default 02 Trailblazer roof ac vents not working
Any idea what would be causing this and a possible solution would be great. All other heat/ac features/vents work, with the exception of the roof vents. Thanks.
Old Jun 2, 2008 | 8:26 AM
EvansBlue's Avatar
Default RE: 02 Trailblazer roof ac vents not working
Have you check all your fuses? If there is no fuse for it, check the ground. If not the ground, either the motor is burned up in the fan or the switch is messed up. Alternatively, if it is equipped with a motor run capacitor ora fan relay, thenthat may be your problem
kawi
Sep 19, 2016 12:13 PM
osbornesd714
Jan 17, 2014 11:26 AM
cjdavis618
Oct 18, 2012 10:11 AM
if1ops
Aug 4, 2010 4:41 PM
tazordep
Aug 10, 2007 6:40 PM
