'03 TB, 6Cyl, 80K Mi, Error code P1481
#05-06-02-012B: Service Engine Soon (SES) or Check Engine Light On, DTC P0480,
P0526/P1481/P1484 Set (Replace Engine Cooling Fan Wiring Harness) - (Oct 19, 2006)
Subject:
P0480/P0526/P1481/P1484 Set (Replace Engine Cooling Fan
Wiring Harness)
[align=left]
Models:
2004-2006 Buick Rainier[/align][align=left]2002-2006 Chevrolet TrailBlazer, TrailBlazer EXT[/align][align=left]2002-2006 GMC Envoy, Envoy XL[/align][align=left]2004-2005 GMC Envoy XUV[/align][align=left]2005-2006 GMC Envoy Denali, Envoy XL Denali[/align][align=left]2002-2004 Oldsmobile Bravada[/align][align=left]2005-2006 Saab 9-7X[/align]
[hr]
This bulletin is being revised to add DTC P1484. Please discard Corporate Bulletin Number 05-06-02-012A (Section 06 Engine/Propulsion System).
[hr]
Condition
Some customers may comment that the Service Engine Soon (SES) or Check Engine light is illuminated. This condition may be intermittent and upon investigation, the technician may find either DTC P0480, P0526, P1481 or P1484 set.
Cause
This condition may be caused by the cooling fan harness chaffing against the plastic guide it routes through. This contact may damage the insulation of the wires enclosed in that harness.
Correction
Replace the engine cooling fan harness using the procedure listed below.
[ol]Remove the cooling fan. Refer to the Cooling Fan and Shroud Replacement procedure in the Engine Cooling sub-section of SI.
Place the cooling fan assembly on a bench.
Disconnect the harness electrical connector from the cooling fan clutch.
Remove the harness from the plastic guide while feeding the wires out of the slot.
Before installing the new harness, wrap the affected area on the wires with electrical tape to keep the protective sleeve in place. Be sure to keep the tape approximately 25mm (1in) away from the connector so the wires can be fed into the slot.
Feed the wires into the slot and install the harness to the plastic guide.
Connect the harness electrical connector to the cooling fan clutch.
Install the cooling fan. Refer to the Cooling Fan and Shroud Replacement procedure in the Engine Cooling sub-section of SI. [/ol]
Parts Information
Part Number
89024920
Description
Harness Assembly, Engine Cooling Fan Wiring
Subject:
Wiring Harness)
[align=left]
Models:
[hr]
[hr]
Condition
Cause
Correction
Parts Information
Part Number
89024920
Description
