TrailBlazer 2002-2009
05 Trailblazer - Electrical Isssues
Old Dec 1, 2020 | 11:30 AM
a1handy's Avatar
Default 05 Trailblazer - Electrical Isssues
I have an 05 Trailblazer with 198,000 miles that are having electrical issues. The problems are intermittent and affect the turn signals, gas gauge, and rear ac/heat unit. Sometimes these items do not work but will begin working again. The truck was in a front end crash and I do not know if these issues were present before the crash. We cannot find any loose connections or grounds. Could this problem be in the BCM? Where can I go from here?
Old Aug 22, 2021 | 2:59 PM
ATGATT's Avatar
Default Check rear hatch wirin
Check harness where the wires enter into the rear hatch. Remove boot and giggle wires around. I found 2 wires had separated, reconnected them 4 years ago no more electric gremlins. Good luck.
Old Aug 22, 2021 | 4:21 PM
hanky's Avatar
I hope you are not checking ground connections by just looking at them, that does nothing.
They need to be loosened cleaned and tightened.
Brian Brost
Oct 29, 2020 7:27 AM
vaughn242
Sep 23, 2020 5:06 PM
Mike Hewett
Feb 28, 2016 5:57 PM
Tidwellrock
Mar 11, 2015 6:53 PM
Diesel5479
Feb 9, 2010 3:47 PM
