TrailBlazer 2002-2009
Crank but no spark.
Old Mar 15, 2021 | 6:38 PM
A.J. Woodman's Avatar
Default Crank but no spark.
03 trailblazer, crank but no spark. There is no power going to the crank sensor, VVT sensor, & the lower voltage wire to all the coil packs has no power, the coil packs are getting the 12volts though. Checked fuses & relays, replaced throttle body, replaced crank & cam sensor, replaced ignition switch. Oh, the cam sensor does have power. What could be the issue? Stored codes were 0014,. 0128, 0171, 0440, 0442,
Old Mar 16, 2021 | 8:29 PM
oilcanhenry's Avatar
P0014 Exhaust Camshaft Position Timing - Over-Advanced (Bank 1)
P0128 Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature)
P0171 System Too Lean (Bank 1)
P0440 Evaporative Emission Control System Malfunction
P0442 Evaporative Emission Control System leak Detected (small leak)
I don't think these issues would prevent your motor from starting up. Might be a bad ECM.
Old Mar 17, 2021 | 4:32 PM
Ya I didn't think those codes were related to no spark either. I'm thinking PCM also. The window does say it has an aftermarket alarm, wondering if that could be the culprit. I bought it off a guy who couldn't get it to start again, couldn't figure it out.
Old Aug 29, 2021 | 3:41 PM
Default Trailblazer no spark
So with this 03 trailblazer, I replaced the PCM with new & still no spark. I noticed when I teat the two yellow & purple crank sensor wires with a logic probe the fuel system pressurized each time I touched bare wire.... why would that happen?
Mario Jones
Jan 20, 2020 8:03 PM
Aldo0280
Nov 29, 2019 10:10 PM
Cornbread9
Mar 18, 2018 6:04 PM
Sweepee
Jul 6, 2014 10:30 PM
bbish0p
Feb 8, 2010 2:17 AM
