Hi guys new to forum & looking for a lil advice
Old Nov 29, 2019 | 10:10 PM
Aldo0280's Avatar
Default Hi guys new to forum & looking for a lil advice
I am trying to fix a crank no spark issue on a 2001 Silverado with 4.3. I have replaced basically every part of the ignition system that i know of including- new & tested icm, new & tested coil, new cam sensor, 2 new crank sensors, & just put a new pcm that was programmed to the vin & still i have a crank no start no spark condition. Ive checked all the usual stuff fuses all good, power & ground to icm, ic, power at ckp, i wasnt getting continuity between ckp & pcm blue/white wire so i actually added a lil jumper wire from pcm to ckp to see if i got spark & still no spark. When i put led test light on signal wire to icm & crank engine the light does not flash which is why i ended up replacing the pcm but still no spark? Idk what else to check i read a couple things online about some wiring in the ignition cylinder? Idk if that could possibly be part of the problem or not but the truck is actually not mine & its a couple hrs away but they owner is supposed to be having it towed up to my house so i can try to figure it out in my garage. Im not really sure where to go from here besides starting all over from beginning & test everything again to make sure i didnt miss anything? I would very much appreciate any other suggestions or advice. Also my good 400 dollar foxwell tablet style scan too will connect & read & clear codes but when trying to read live data it will connect for a sec then say no communication? Which i know my scan tool works just fine on any other vehicle but my other cheaper launch creader scanner does connect & in the live data it shows no ckp or cam sensor signals? Although when reading engine speed its showing engine rpms while cranking so idk why its showing no ckp signal?
zbeamanx2
Dec 20, 2018 10:32 PM
darrenbrigman
Oct 24, 2018 4:18 PM
VFax92
Oct 9, 2018 2:08 PM
travismm
Feb 25, 2014 4:09 AM
redneckjames
Oct 19, 2011 8:02 AM
